DIYPC GAMEMAX-W WHITE DUAL USB 3.0 ATX FULL TOWER GAMING COMPUTER CASE WITH BUILD-IN 5 X BLUE FANS - 2 X 120MM LED FAN X TOP, 2 X 120MM LED FAN X FRONT, 1 X 120M DIYPC Gamemax-W White Dual USB 3.0 ATX Full Tower Gaming Computer Case with Build-in 5 x Blue Fans (2 x 120mm LED Fan x Top, 2 x 120mm LED Fan x Front, 1 x 120mm LED Fan x Rear), Water Cooling Ready Motherboard Compatibility: Micro ATX / ATX / Mini-ITX Front Ports: 2 x USB 3.0 / 2 x USB 2.0 / Audio 120mm Fans: Front: 2 x 120mm LED Blue Fan (Pre-Installed) Top: 2 x 120mm LED Blue Fan (Pre-Installed) Rear: 1 x 120mm LED Blue Fan (Pre-Installed) Power Supply Mounted: Bottom Side Panel Window: Yes External 5.25" Drive Bays: 1 Internal 3.5" Drive Bays: 4
Price: 69.99
