DIYPC D480-BK-WINDOW BLACK DUAL USB 3.0 ATX MID TOWER COMPUTER CASE WITH BUILD-IN 5 X WHITE FANS - 2 X 120MM FAN X FRONT, 1 X 120MM FAN X REAR, 2 X 120MM FAN X T DIYPC D480-BK-Window Black Dual USB 3.0 ATX Mid Tower Computer Case with Build-in 5 x White Fans (2 x 120mm Fan x Front, 1 x 120mm Fan x rear, 2 x 120mm Fan x top), Fan Controller Motherboard Compatibility: Micro ATX / ATX / Extended ATX Front Ports: 2 x USB 3.0 / 2 x USB 2.0 / Audio 120mm Fans: Front: 2 x 120mm White Fan (Pre-Installed) Rear: 1 x 120mm White Fan (Pre-Installed) Top: 2 x 120mm Fan (Pre-Installed) Power Supply Mounted: Bottom Side Panel Window: Yes External 5.25" Drive Bays: 2 Internal 3.5" Drive Bays: 2
Price: 49.79
