COUGAR EVOLUTION BLACK SECC ATX MID TOWER COMPUTER CASE WITH DUAL 12CM COUGAR TURBINE HYPER-SPIN BEARING SILENT FANS, 2 X USB 3.0, 2 X USB 2.0
COUGAR Evolution Black SECC ATX Mid Tower Computer Case with Dual 12cm COUGAR TURBINE HYPER-SPIN Bearing Silent Fans, 2 x USB 3.0, 2 x USB 2.0 Motherboard Compatibility: Micro ATX / ATX Front Ports: 2 x USB 3.0 / 2 x USB 2.0 / Audio 120mm Fans: Front: 2 x 120mm (1 x 120mm Front Cougar Turbine 1200 RPM 17.7dBA Fan (Included)) Top: 2 x 120mm (Optional) Rear: 1 x 120mm Rear Cougar Turbine 1200 RPM 17.7dBA Fan (Included) Bottom: 1 x 120/140mm (Optional) Left side: 1 x 140mm (Optional) Power Supply Mounted: Bottom Side Panel Window: Yes External 5.25" Drive Bays: 6 External 3.5" Drive Bays: 1 (Converted from 5.25'' bay)
Price: 89.99
