ANIDEES AI7 ATX CUBE CASE DUAL CHAMBER DESIGN - USB3.02, USB2.02, FAN HUB, BLUE LED FAN 4 FRONT, 240MM RADIATOR SUPPORT anidees AI7 ATX Cube Case Dual Chamber Design - USB3.0*2, USB2.0*2, Fan Hub, Blue LED fan *4 Front, 240mm Radiator Support Motherboard Compatibility: Micro ATX / ATX / Mini-ITX Front Ports: USB 2.0 / USB 3.0 / Audio 120mm Fans: 5 Power Supply Mounted: Bottom With Power Supply: No Side Panel Window: No External 5.25" Drive Bays: 1 External 3.5" Drive Bays: No
Price: 99.99
